Hi, I have mobo Supermicro X9DRi-LN4F+(https://www.supermicro.com/products/motherboard/Xeon/C600/X9DRi-LN4F_.cfm) and I want to connect 6 GPUs to it.
When I connect 3x RTX3060 directly through 16x pcie slots everything works fine.
But when I try to use 8x to 16x riser and attach to it one card, the system isn't seeing this card at all. I tried to coennect and disconnect another cards and also tried to use both 8x pcie slots.
I also reinstalled nvidia drivers and everytime I stuck at working perfectly at 16x slots and nothing work on 8x slots.
I am using these risers: 8x to 16x riser ALIEXPRESS - photo attached.
In BIOS every slot is enabled and set to gen3.
Do you have any suggestions how to fix it?
