- 14 Apr 2004
- UK
Hi,
I've seen many peeps talking about SuperPi here.
I download the mod 1.4 version as I've seen that in many screenshots here.
However, there are loads of benchtests (select digits drop down menu) you can run in it. Which one do you guys use to compare results with each other?
Also, what figure do I look at to compare one machine against another? Is it the time that displays when you load the program? Is a lower time better than a higher time?
Thanks guys.
Thanks guys.
