- 20 Jul 2006
Card is getting quite heavy at the front and bending a bit, I need some strong tension wire that I can use to suppor it, three holes at front of card for Cable ties to go through which can then be attached to drive cage to support card. Holes for drive cage are to small though for cable ties, need some tension wire?... or somethign as thin as standard wire, do they make cable ties that thin?
