Im putting together a small home server around an atom mini-itx board. Im using a case which does not have holes in the rear for expansion cards to poke out the back.
I want to install a sata controller in a PCIe x16 slot because there aren’t enough onboard sata ports.
If I get a controller card with only internal ports (like this ), do you think it would be OK to remove the back plate and just leave the circuit board plugged in to the board without support?
Are there any retail products designed to keep cards in the slots with the back plate removed?
Thanks
Thanks
