Suppressing rows in Crystal Reports
~J~
~J~
20 Oct 2003
London
Ooooo, this has got me!!
Got a report on my screen, text labels down the left with field values on the right, something like...
Sales £100
Expenses £200
Rent £400
etc.
There are several 'value' columns, dealing with actuals, budgets, variances, etc.
What I need to do (or rather the customer wants!) is to suppress a line if every value is a zero.
For example the following 2 lines would be shown...
Sales £100 £200 £300 £0
Expenses £300 £0 £150 £2
But if one of the rows is full of zeros, then it totally hides the line.
I know there's an option to suppress fields if they don't contain a value, but I need to suppress the entire row (including the label), thus automatically shifiting every other row up if the entire row is full of zeros.
Any ideas if this is possible?
iirc in crystal reprts the report istself is based on a query? why not add a where clause to the query that will not return the results IF all the values are zeros?
HT
Already tackled that mate, trouble is if the query doesn't return anything, for example if "Rent" is nothing, then I can skip over it on the SQL query no problems.
However, I've not got a 'fixed' and hardcoded label called "Rent" which needs to be supressed seeing as the query has returned nothing.
meh, sorry I can't help you then, I remeber the last time I looked at Crystal rports I abandonned them as an expensive and fairly poor solution for report generation and I ended up writing my own PS / HTML and RTF generator classes.
not a whole lot of help I know. Have you tried the gotdotnet or msdn newsgroups?
HT
Yeah tried them, no joy really.
I think i'll need to create the code in the formula, not that much of a problem other than time really as there's 8 columns with about 36 lines of nominals so that's about 192 formulas need writing.
Cheers anyway, appreciate it.
