** Supremacy Upgrades and New Pricing on all OcUK Tech Labs Watercooling Kits **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
I am pleased to announce a new addition to our watercooling kits.
Every 'Tech Labs' watercooling kit now comes complete with the ground breaking EK-Supremacy - CPU Waterblock.
This is the latest block design from EK and offers superior hydraulic performance over the older supreme blocks and due to improved design, up to 20% higher flow compared to EK-Supreme HF
Check out the full range of Tech labs kits as well as pre configured kits from our leading watercooling partners HERE
OcUK Tech Lab - V6 Watercooling Kit 120 @ £114.98 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike
Component List:
1X XSPC EX120 120mm Radiator
The latest radiator from XSPC, outstanding performance and superb quality
1X XSPC 200 Bay Reservoir & Pump - Clear
A clever space saving solution that allows you to see your coolant level from your drive bays
1X EK-Supremacy - CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supremacy' for a reason!
1X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fan
The most recognised performance fan for watercooling radiators.
1X Mayhems Coolant
Pick your own coolant that suits your taste and style
1X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Silver Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is available on our forums).
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Was £119.99 Inc. VAT
Only £114.98 inc VAT.
ORDER NOW
OcUK Tech Lab - V8 Watercooling Kit 240 @ £184.98 inc VAT
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X XSPC EX240 120mm Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X EK DCP 4.0 Pump
A superb all round pump with a small footprint inside the case
1X EK Reservoir Combo DCP 4.0
A powerful aftermarket top and reservoir combo to ensure maximum performance from your Pump
2X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
1X Mayhems Coolant
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish
IMPORTANT:
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Was £189.99 Inc. VAT
Only £184.98 inc VAT.
ORDER NOW
OcUK Tech Lab - V10 Watercooling Kit 360 @ £229.98 inc VAT
Designed with a small footprint in mind, the components in this kit maximising cooling capacity
Component List:
1X XSPC EX360 120mm Radiator - Black
Offering superb performance, build quality and value the XSPC EX range of radiators are the obvious choice for high end watercooled systems.
1X Laing 10W DDC-Pump 12V DDC-1T
The best small footprint watercooling Pump on the planet.
1X XSPC Acrylic Tank Reservoir for Laing DDC
A Reservoir that fits on the top of the DDC pump with proven performance.
3X Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin Fans
1X Mayhems Coolant
2X XSPC 7/16" ID [16/11mm] Clear
2X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish
IMPORTANT:
This kit can also be upgraded with an additional VGA waterblock!
You will need to buy two additional fittings alongside your graphics card block.
Please ask our friendly sales team for VGA block advice.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Was £234.98 Inc. VAT
Only £229.98 inc VAT.
ORDER NOW
OcUK Tech Lab - V12 Watercooling Kit 360 @ £264.98 inc VAT
Component List:
1X 12V Alphacool Laing D5 Vario Pump 655
The best watercooling Pump on the planet. Accept no substitutes.
1X EK-D5 X-TOP CSQ - Acetal
A powerful aftermarket top to ensure maximum performance from your D5 Pump
1X XSPC Single Bay Reservoir - Multi Fascia
A high flow reservoir for your D5 providing an easy filling and draining point in your loop.
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
1X Mayhems Coolant
8X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish
IMPORTANT:
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
***NOTE***
Was £279.99 Inc. VAT
Only £264.98 inc VAT.
ORDER NOW
