surely this cant be right help!!!!!!!!!!!!
Permabanned
7 Jun 2007
i have a geforce 8800 gts 320mb card point of view.
the stock core is 513 and memory 792.
using rivatuner ive managed to get this to core 740 and memory 1000!!!until it dosent pass the test.
is this right?seems a bit wrong to me.surely u cant go up this much.
can you over wind the card?and if so what do u do about it.
no this is just it
it dosent
listen ive just found out something weird.
using nvidia monitor you no where u look at the two boxes that are green under bus speeds.it shows ure gpu core and memory speeds?
well if i clock it to 610 core and 950 memory the boxes turn yellow which means higher bus speeds i assume.but if i clock it higher the boxes go bak to green.why u wouldve thought thed go orange or red?do you reckon the yellow is the max overclok i can go and wen it goes bak to green wen i go higher its just not overclocking but looping maybe.anyone no about n monitor and these box colours help me.
