Surf Photography
7 Jun 2010
Wales
Well as a hobby I surf and I also have an interest in surf photography as I have several mates that I can get some crankin shots of! I have a 450D but only with a stock lense and a wide angle.
Anyone on the forums do this type of photography? If so post some of your stuff in here!! Also anyone got a suggestion for a good lense to get me started off? I dont want to spend a lot on it tho as I most likely wont be selling the images.
Post your surf / water sports pictures !!
When I lived in California I surfed a little and took my camera. Depending on location obviously they are at different distances. I found 300mm to be ok but wished I had a bit more.
And Since the surfers will tend to move in towards you the ability to zoom is more useful than in many other applications.
I reckon the canon 100-400 is optimal, but a good 70-300 will suffice for less budget. 200mm wont really be enough.
I have only shot surfers a few times at Santa cruz though.
I've done a little, will dig some shots out when I'm home. Good shots are hard to come by generally - if you're shooting from shore you need a decent long lens, I liked the Nikon 200-400 and it's popular but anything like a 70-300 will be a good starting point.
Not much help really - I was never particularly good at it...
How about a 300 f/4 and a 1.4 TC. Probably a better bet than a 100-400. I know from a few surf competitions I've walked through in Cornwall a lot of people are standing in the water using 500+ primes.
Obviously though if you don't want full frames something like a 70-200 would work.
300 f/4 can be got for £400-450 used
1.4TC ~£190
70-200 f/4 ~£370-400
Cheers for the feedback guys, would love to see some of your shots. I think a budget of 400 would be maximum so maybe I could pick up something second hand.
As for the lighting conditions as it is now coming into winter now itll be mostly overcast. There are a few local photographers I could speak to and maybe buy one of there old lenses!
Not keen on the in water photography - it's a bit keen and if im gonna be in the water id prefer to be on a board :P
As mentioned, telephoto zooms are almost uniquely useful here, but a 300 + TC14 would do at a push. I'd rule out the 70-200 though, even on a crop body shooting from some rocks in the water it wasn't really enough at the long end (it's a good one for a second body though if you're taking it seriously!). For fun stuff I think whatever the Canon equivalent of Nikon's brilliant value 70-300 VR is you best bet.
In feature terms, good AF is a must and VR/IS is highly desirable as a tripod won't always be an option...
Wow yeah, the 70-300 VR is great value, I will have to look for the canon alternative. £315 new is just what I would be looking for.
Edit: I believe it is the Canon 70-300 IS
Just going by what I've seen "pros" using in big competitions, all of which appear to use big primes. :)
70-200 would be a nice focal length for the "surfer in waves/sea" shots as I mentioned, not looking at full frame shots with them in.
OP personally for £400 I'd go for a 300 f/4 used, no IS but then you'll be needing a fast shutter speed anyway (and probably using a tripod/monopod most of the time). It's also a damn sight sharper than the 70-300 at the 300 end and it has a lot faster AF.
This is a 4.5MP crop from a 6MP photo taken at 300mm on a D70 (1.5x Crop). The location is a beach about 30 minutes north of Santa Cruz where you can walk out on a rock ledge to get close tot he surfers.
He is looking away as I use the photo for stock, and the composure just sucks as I took about 7 years ago now but it gives you the idea of the kind of reach you need.
Shots would probably be up to a 100 metres.
Nice shot D.P that would be the kind of thing I would be wanting to shoot!
All the best surf photography I've seen are shot IN the water. Reason being that is an angle you don't get to see as a spectator and which ultimately makes it more special.
Yes I know that in the water shots are more impressive (sometimes) but that's not what I am interested in. Its a hole new ball game, you have to get full water housing kit, flippers, even thicker wetsuit than I already have as I wont be moving about as much as I would be if I was surfing, and the ability to swim for long enough without a float.
But if anyone has in water shots post em up!!
Some I took recently of wakeboarding, though I was in the boat :p
Shot with 18-105mm VR lens, could have done with 200mm though...
