Surface area question
Caporegime
24 Dec 2005
Autonomy
If I buy these are 305x 305 mm each there are 24 tiles in a pack £29.50
If I buy These are 1000mm x 500mm per unit £5.50 each
How many of the big tiles do I need to cover the same area as the small ones?
Which Offer the best value?
5 of the bigger gets you more coverage at a lower price.
And I'm assuming your units are wrong on the second one.
There are 2.2326m2 in the first pack so £13.21 per metre
The second pack is 0.5m2 so is £11 per metre so much cheaper. You need 4.46 big tiles to cover the same area.
However as Orionaut said, the bigger the tile, the more wastage you have depending how many corners you have.
My whole garage is covered in this stuff because it was a music producers studio, it's also got carpet and lighting that look like they've been recovered from a strip club.
hey,
I've not compared prices yet but it's probably cheaper to get them from efoam.
I had close to a cubic metre of acoustic foam cut into 60mm slabs from them.
they cut any size you want and sell by volume. they have the egg-crate profile too.
https://www.efoam.co.uk/index2.php?shape=ACrectangle
prices on their site are live, and it gets lower and lower as you add more :)
Efoam is 4 x time more expensive mate
Quote for foam cut to size
Your selected shape: Acoustic foam rectangle
width 500mm, length 1000mm, thickness 40mm
£16.28 then 6.78 each after
If I buy These are 1000m x 500m per unit £5.50 each
ah okay no worries, it's a while since I used efoam and I remember the price to add one more just got lower and lower and lower, so by the time you had 12+ panels and extra one was aonther quid or so. it might have changed now (unless you try adding one more etc etc.)
certainly was the cheapest way to do mine but they were 1200mm x 600mm x 60mm board backed, wrapped panels.
(http://i.imgur.com/KyiK0if.jpg - setup in old rented house, now stored until I get my act together in new owned house)
Is the floor soundproofed as well?
acoustic panels have absolutly nothing to do with soundproofing, and vice versa.
