Surface Pro 3 image
19 Jul 2006
I'm having a bit of trouble we changed domains at work and now we cant access some surface pro's. No one knows the local admin password or it has been disabled.
I am having a try with hirens to see if we can get in that way. Otherwise its a factory reset which tbh would not be that bad.
Is it best to use the https://www.microsoft.com/surface/e...ervice-and-recovery/downloadablerecoveryimage the surface recovery image or download windos 8.1 from our licence key
Just buy ActivePasswordChanger. Its well worth the small price to avoid factory resetting.
I use it for exactly the same situation you are in right now. :)
