Surface Pro 3 Multi-Monitor Display Question
24 Sep 2007
Hi Guys
With the Surface Pro 3, what is the best way to create a setup of tablet screen plus two external monitors? I've seen that there is a Surface Pro 3 dock that will enables this setup by giving an additional Mini Display Port. However, it's £164.99 so I was just wondering if there was a better and cheaper way to do it.
Thanks :cool:
You can connect the Surface Pro 3 directly to a monitor via it's Mini DisplayPort, and if the monitor supports it, you can daisy chain another monitor to it via DisplayPort. You could also use any USB port replicator with multiple video outputs.
