Hi people
I have a surface pro 4 bought used for my daughter i5 128gb turns out there was a password on windows 10 login screen asking to login which we didn't no it, so watched a online videos held the power and shift on boot up could get to advanced reset this PC chose to remove all files setting kept saying there was a problem and just goes back to advanced settings screen
So then I try'd to go into the bios to change the boot setup but no a pass word only letting me see basic info.
I've now dropped it in to a local shop I shown them I could get into the C: by trying to find a image in advanced settings they must have now right clicked reformatted the C: now soon as boots up goes rite to password no windows login because it's easy to tell they reformatted the C: this is what I found out the the day after leaving it with them so I give them a peace of my mind and said it's worse now then when I give it you....so his friend is saying it needs taking apart I'm pose to collect it tomorrow but I can't see how there can fix it because of the incription on uefi to change boot order..... I see a couple of people said to put the M2 connected to another pc put windows back on it build back up....but won't it still be incripted via the bios and could some please help any advice should be great
Sorry for the long story
