Hi all
I was wondering if anyone has gone down the route of protecting their entire electrical system using a surge protection device in the consumer unit?
I'm currently about to get a re-wire undertaken and I'm just looking at specifying my needs to the electrician.
I noted Hager have an SPD available that fits between the incoming isolator and the busbar. This means that individual surge protected socket strips will no longer be needed, the entire system is protected.
The downside, it's expensive at £200+ for the module.
Not sure if I will go with it yet...
Mike
Mike
