Surge protector advice/questions
15 May 2006
Hi,
I have a set of logitech surround speakers, and fairly often the 2a time delay fuse would blow in them. One day I came to the speakers and the unit didnt work at all.
I had a warranty replacement, and within a few days the unit had blown again.
Basically im not sure why this is happening, I dont know if its poor wiring of my flat, or the sockets overloaded but I want to prevent it from happening.
Would a surge protector help? at the moment its a cheap 4 way gang. Also would a surge protector help protect devices if the socket became overloaded, eg, to many electrical devices plugged in at once.
Any finally, any specific surge protectors you guys would recommend?
Thanks
Hi,
Thanks
It would help, but bare in mind it'll blow the fuse in the surge protector and you'd have to keep replacing the fuse in that.
Depending on the model/make you choose, it might also automatically switch the power off if the fuse breaks.
surge protectors are a must in my opinion, quality ones are relatively cheap (I use a belkin) and may save you a lot of money in hardware - at the very least it gives me peace of mind.
Do you have 5000/5500 by any chance? Supposed to have a well known fault for blowing fuses. If nothing else blows on the strip then the log at fault.
A surge/spike protector will help reduce the damage in the worst case scenario. A UPS is even better though.
Thanks guy, have gone for a Belkin PureAV
Is there anything further I could do to help protect the Z-5500's? They were the only thing that blew on the strip
