stokefan said:are surge protectors worth getting?
I have a 6 plug Belkin one, but I want anohter one for my PC, does brand matter either?
) do our best to prevent surges with our own high tech kit (a couple of metal rods with a gap in-between
) but surges can still happen, mainly during harsh weather conditions. Your kit would probably be safe from most things with a normal fuse, but if you want to get a surge protector it won't do any harm and at least you'd be protected if the worst did happen
badbob said:You won't have any problems at all. I have a 8 way block, with a another 6 way attached to that. 8 poweramps, TV, CD, 2 DVD player, HT processor, pre-amp, DAC, tuner. Never tripped the mains fuse.
The fuses are only there to protect the device in a worse case scenario. A CD player does not use 3A of current, for example.
scary! for local assistance with fire call 999marc mercer said:I have a couple of belkin 8 way pure av and surgepro protectors. Both look good, compensate if components get damaged by a surge - and have added protection for ethernet and AV connections (depending which one you go for)
The only thing i don't like is that the on off switch on the unit is quite easy to flick by accident. I have found that sometimes the plugs (particularly power bricks) don't quit go in properly which can cause horrible crackly electrical noises and then the surge protector cuts the power. I'm not sure if that is unique to my one or a build qualty issue
the z5500 speakers make a masive bang sound if I switch off the issolator before the speakers too. Im not entirly impressed with it.stokefan said:are surge protectors worth getting?
