Surround sound clips
17 Mar 2004
Anyone with MCE2005 knows about the startup noise it makes (frankly annoying) I am trying to find a surround sound clip 5.1 to replace this. Does anyone know of any sites hosting anything upto 5secs worth?
hardc0re_tid said:
use
www.4shared.com and allow people to download the file
:confused: Wrong end of the stick, somebody has.
I am not entirely sure whether you can get a file in 5.1 that is compatible as a Windows Start-up/Shut-down sound. It would need to be a wav file (I think) and they can only be mono or stereo. You could get a surround effect if your PC is connected to a Pro-Logic amp, but it still wouldn't be 5.1.
The only other way would be to enable Environmental Audio (if using a Creative sound card), which would give any sound the appearance of being 5.1.
