- 1 Oct 2020
As the title suggests, I'm trying to get a surround sound output via HDMI - I've read quite a few conflicting threads about this and whether it is possible, but don't feel anywhere near the answer.
My setup is a PC in the office, connected to a regular monitor via Displayport on the GPU, and to the TV in another room via HDMI 2.0 from my GPU. The setup on the monitor is not an issue (the motherboard connects directly to studio speakers in the office) and works well. The surround speakers are connected from the TV to a Sonos Playbase via optical, and as far as I can tell all sound processing via the TV is turned off, and should just be passing through the signal received by HDMI. However, the app is telling me that the signal being received is only Stereo PCM 2.0. When testing window sounds, if I select speaker setup to surround, I can get test output on Center front, left and right, but no output from the rear speakers or subwoofer. if I change the output to Quadrophonic, then the rear speakers can work, but still no output from the sub.
The HDMI port I am using is definitely 2.0, and I am confident that the cable (20m, but buffered) is working correctly as the TV is able to display a 4K, 60fps image with HDR enabled. Does anyone know of a way to ensure that the sound being transmitted is 5.1, or is this not possible? I appreciate that not everything will be in 5.1, but I would like it to be possible where applicable, and am running out of ideas of things to try. It is entirely possible I'm missing the bleedin' obvious.
Let me know if any more information would be useful, and thanks to anyone that is able to try and help!
