Hi,
A survey I had done stated the following regarding the house's electrics.
- Installation may not be in strict accordance with current regulations - normally advised that an installation is inspected every ten years.
- No evidence seen of any current inspection certificates
- The wiring to external lights around the corner of the house is protected in plastic ducting but the ducting is significantly deteriorated and should be replaced.
Is this something I should be concerned about? External lights are no big deal, but I have no idea how significant an inspection certificate is? Can it cause insurance problems?
House is late 1920s - I guess probably original wiring.
Thanks
Thanks
