Following on from this thread I suspect my retail i7-2600k CPU has died.
Basic configuration is as follows:
One day I was using it without issue, switched it off as normal to get some food. Shortly afterwards I tried booting it up again and it wouldn't POST. Q-code LCD on the motherboard just said 00. It initially shows 00, then shutdown then start up again, after that it would show 00 forever with the fans spinning but no POST or beeps.
Thinking perhaps the motherboard had died I removed it and got it replaced under the Sandybridge recall program. I received the new B3 board back from ASUS last Friday, rebuilt PC and tried switching it on and was surprised to find it doing exactly the same thing as the old board.
Things I have tried/eliminated:
Is it possible for a CPU to just randomly die? I've never had an Intel CPU fail on me out of the blue, especially one that is barely 2 months old.
Would appreciate any help/assistance anyone could provide. Additionally if there is anyone in the Westbury/Trowbridge/Wiltshire area who wouldn't mind helping me see whether it definitely is the CPU that is faulty I would be hugely grateful and would shout them a beer or two
Sorry for the long post but thought I'd give as much details as possible.
- ASUS Maximus IV Extreme
- Intel Core™ i7-2600K CPU (8M Cache, 3.40 GHz)
- 8GB G.skill Ripjaws-X F3-17600CL9D-8GBXLD
- Antec Signature 850W PSU
- Noctua NH-D14 heatsink/fan
- Graphics cards - neither are installed, PC doesn't get as far as even acknowledging with beeps that there is no video
- Memory - PC does the same thing whether memory is installed or not, does not acknowledge if no memory is installed at all
- Motherboard - it is conceivable that I received a DOA B3 motherboard from ASUS, but for it to behave in exactly the same way as the old (presumed defective) board is a bit too coincidental?
- Loosened the heatsink screws slightly (maybe too tight?)
- Removed motherboard completely from case and tried running it on a cardboard box (assuming mobo was grounding on case) - same result.
