suspension problem?
5 Aug 2006
Derbyshire
my micra (2000) seems to be tilting to one side. I have checked with a tape measure the distance between the top of the tyre and the arch on both front wheels and the difference between them is about 4cm iirc. One wheel is clearly too high in the arch and the opposite one is clearly too low.
I know this is a bit of a vague description, will try and get pics if it stops raining. I am assuming something suspension wise is buggered? Should I get it on ramps to see which wheel is actually the one thats at the wrong height? Just looking for guidance really, as like many I beleive that garages try and rip you off at any chance possible.
TIA
