Every few seconds, like 3 or 4 seconds - I'll get a what seems like a 0.5 second pause, though it could be much less than that. This seems to be after the PC has been on for a few hours, unsure if this is after some intensive use or with little use beforehand (will have to try and take note prior to this issue occurs).
Newly built PC - spec is:
AMD Ryzen 5 2600X
ASUS Prime 450 Plus Mobo
Samsung 970 Plus 500gb Nvme m2 SSD
Corsair 3000Mhz 32Gb (2x16) RAM
Linux Mint 19.1 Cinamon (Fresh Install)
This happens whether I'm dragging a window around the desktop or even when watching a youtube video. Once I notice this occuring, I've found that if I restart Cinamon via the troubleshooting menu the problem goes away for a while, but always comes back.
I didn't notice this issue running on older intel hardware with the same OS/Desktop.
Has anyone else experienced this issue with similar hardware/software? I wonder if it's a Cinamon problem or maybe some driver issue?
AMD Ryzen 5 2600X
