svideo interference when using external usb HD
16 May 2005
Hello.
I'd recently noticed some interference appearing on my LCD TV when using the svideo out connection from my PC. Oddly enough it does not occur when I use the svideo to connect to my old CRT TV. Because of that, I always suspected a faulty svideo connector on the LCD TV.
It was particularly bad the other night while I was watching a film, and for some reason I decided to try switching off the external usb HD I store all my films on. Low and behold a perfect picture. Switched it on again, and there was the interference again! So having the external HD switched on is causing interference. I tested switching it on and off many times, and even different usb ports.
Any ideas what could be causing this?
The MB PSU QUAD are pretty new. I never had this problem before. I'm stumped to why it only occurs on the LCD and not the CRT.
The LCD TV is about 7-8 meters away from the PC and HD, so not exactly close at all.
The external is a enermax caddy with a maxtor diamondmax HD inside it.
