Hi OcUK,
I'm currently somewhat triple booted, with three hard drives, one with the OEM Windows Vista from what my PC originally was (Packard Bell machine), another drive that is 335GB, which I then shifted to Windows 7 RC with, then I moved onto my 1TB drive with Windows 7.
Now, I recently swapped GPU makes and this 1TB drive is becoming full of junk programs I no longer use.
I was wondering what would be best out of these three options -
My 1TB drive is a Spinpoint F3 and my two smaller drives are both ST3360320AS
- Moving my 342GB of user files onto my two other drives (if they fit), wiping my F3 and installing windows on that drive (I may also wipe another smaller drive just to fit everything on)
- Moving files from a smaller drive onto my F3, wiping the smaller drive and installing windows on that, using my F3 as my files
- Buying another drive all together (My Antec 300 is a bit cramped with a GTX480 inside though)
