Hi guys
I've removed a cpu from another machine, however after placing it in my another system seam it's having bad heat issues, I haven't booted it in to windows yet, just by looking at the heat data in the BIOS. climbing from 60 to 80C in just 60 seconds...I shut it down at that point as something clearly is not right.
the mobo temps are 25C as I have a few larger fans in there, so that seams fine.
I have a coolermaster fan on the CPU, although a PITA to fit seams to be seated ok.
I have not used any paste and the CPU is about 18 months old. I will purchase some tomorrow, do you think it is down to this?
Thanks
Thanks
