Swapping H100i v2 for H150i Pro XT - Intel Bracket
5 Jul 2006
I’m considering swapping my Corsair 240mm H100i V2 for the 360mm H150i Pro XT.
Does anyone know if they use the same Intel CPU bracket? Ideally I would like to avoid the hassle of removing the existing bracket from the motherboard and would prefer to simply clip on the new pump to the existing bracket if it’s the same?
Muchos Gracias
Most likely yes. But not sure sorry.
I posted because I'm just interested in why you'd bother. Not good temps?
Temps are ok to be fair (circa 65-70 under load) but would ideally like them a bit lower.
I’ve bought a couple of extra Noctua 140mm fans to improve air flow in the case, I’ll give them a try first to see what difference they make and then will most likely try the H150i.
