Swapping out a replacement 8206zl
7 Jun 2003
Gloucestershire
This may seem as a stupid question to some of you but as i've never had to do it before i want to check the proper procedure...
Soon i'll be swapping out a faulty HP 8206zl with a new chassis, i've taken a backup of literally every config file and flash that i think i can.
Am i right in thinking that by exporting the flash that everything from firmware version to the routing setup should be included making that the only file i'll actually need? or will i need to import the running-config and/or startup-config as well?
Do a write memory and tftp the running config to a TFTP server. When you have the new switch up and running on the network with a basic config, just do the reverse and TFTP down the config and give it a reboot. It will be working as the old one did.
The commands are (from memory so check) :
copy running-config tftp tftp-server-ip filename <--- upload config to TFTP server
copy tftp startup-config tftp-server-ip filename <----downloads config from TFTP server
Just to be on the safe side i've done all of the following:
copy startup-config tftp tftp-server-ip filename
copy default-config tftp tftp-server-ip filename
copy flash tftp tftp-server-ip filename primary
copy flash tftp tftp-server-ip filename secondary
Just to be on the safe side, but i was thinking that rather than using the configs, if i used the flash then wouldn't it have the exact same firmware version included?
