Swapping TPM Module around?
18 Oct 2002
Behind you... Naked!
Possibly a stupid question, but hopefully a good one.
A few weeks ago, I kind of noticed that one of my Motherboards has a TPM Port. Now, that in ityself didnt do anything for me, but I also noticed that another one of my boards has a TPM Module that I can unplug.
I ignored these for a short while, and then, I simply took it out of the one board as it wanted me to upgrade to Windows 11, and then I thought... Can I use that Module in another board? It does fit, but would it be saafe to try it?
This is purely because my daughter is using the setup that has a port but not the module, and if it took the module, then it would upgrade automatically wouldnt it?
Just thinking?
Pretty much any PC that supports Windows 11 will already have a TPM through the platform that you can enable in the BIOS (though sometimes an update is required).
Removing a TPM module can bork the Windows install if you use stuff like Windows Hello or Bitlocker.
The TPM Module that I am talking about is a physical thing, that plugs onto the board. Sure some of my boards have a BIOS option to enable/disable, but on these particular boards, its a thing that simply plugs in and out.
What I have done, is installed Windows 11 onto one board that has it, however, is a fairly low end setup ( AMD A8-7800 ) and I have taken that thing out and it has NOT affected the install ( AFAIK? ) and it does physically fit into another board, but I have NOT powered the thing up, just in case???
I could absolutely simply put a funky install onto it, but I dont want to.
The ONLY PC that I really dont want Win 11 on, is my main PC and thats gone and updated behind my back and I am genuinnely annoyed cos its now slower than ever. Even Notepad takes a few seconds to load up, and my games are sometimes jerky.
Yes, I know. My point is: any CPU that has official support for Windows 11 should not need one.
Yeah, I think the requirement for TPM 2.x is only checked during install time, you can disable/remove the TPM once Windows is installed. The exception is if you use features that rely on the TPM, like Windows Hello or Bitlocker. Removing a TPM with Bitlocker enabled can prevent you from accessing the storage anymore.
From memory
When the whole you will need a tpm
For windows 11 started
People were scalping on tpm modules
Before the fact built in cpu tpm would work
Became apparent
They were definitely selling board/manufacturer specific modules
So it might fit
Will it work is a different matter
Could it cause any damage if it's board specific?
Don't know
But there's other risk free options
Software like flyby11
Should allow upgrading without a tpm
Software like rufus would allow clean install
Without a tpm
There's also some trick I haven't tried
It's something like use server edition for install
Until it passes the checks
Then remove it and put in normal windows media
And finish the install
