28 Dec 2009 at 13:07 #1 willhub willhub Caporegime Joined 3 Jan 2006 Posts 25,281 Location Chadderton, Oldham Is this a worthwhile swap? I have my dads old phone (K800i), and my dad wants to swap his newish phone (C902), back for it, he says he does not like it. Should I swap? Thanks Will.
28 Dec 2009 at 14:06 #2 UnworthyBean UnworthyBean Associate Joined 15 Jun 2009 Posts 2,494 Have a play with the C902, Thats the only way you can decide. There isn't much improvement over the K800, Apart from a better resolution camera but lacks the Xenon flash for a LED flash. Its slightly smaller too.
28 Dec 2009 at 14:11 #3 willhub willhub Caporegime OP Joined 3 Jan 2006 Posts 25,281 Location Chadderton, Oldham Ok, well due to the better camera quality I have decided to go for swapping. Only thing I am confused is that I am trying to swap over text messages and contact information, how do I transfer them over??? Thanks Will.
28 Dec 2009 at 16:00 #4 UnworthyBean UnworthyBean Associate Joined 15 Jun 2009 Posts 2,494 Contacts you can just blutooth across or save them to your sim card if you are going to reuse it. As for text messages, Im preety sure you cant transfer them.
28 Dec 2009 at 16:11 #5 willhub willhub Caporegime OP Joined 3 Jan 2006 Posts 25,281 Location Chadderton, Oldham Thanks, I did it via PC Suite eventually, quite handly software that
