Yup i mounted it in the roof, bit of a tight fit with the psu but its all there. I got an ac ryan grill to go over the top, just need to get some neater screws to finish it off. If you do this make sure you measure twice and cut once
With the apex kit I found that I needed to re-rill the holes on the water block as they were too tight.
EDIT:/
Temps are 33/36 idle and 45 under load, ambient is 20c with the fans at 5v, that’s cooling a E6400 @ 3.2ghz and a 1900xtx. Need to get some decent fans but not had time to source some yate loons. oh and case is about 22/23c.
