Swiftech external radbox and 120.3
Man of Honour
19 Oct 2002
Surrey
Does anyone know if it's possible to mount the MCR320-QP 120.3 rad in the MCB120 radbox (the one that hangs off the back of your case)? Obviously assuming the case is tall enough :)
Yes, I'm sure it says that in the specs somewhere.
Swiftnets.com said:
The MCB120 revision 2 "Radbox" retains all the functionalities of the orginal but is now made of injection molded plastic, and receives several cosmetic enhancements:
* a gorgeous silky black paint finish,
* the edge of the housing now overlaps the base plate for a cleaner, more pleasing look,
* and the silver Swiftech logo is applied on the side highly contrasting with the black background for a rich finishing touch
Mechanically, the product is very sturdy thanks to the base plate featuring numerous reinforcement ribs, and it fulfils its function to perfection. The MCB120 Rev2 "Radbox" can support single, dual or triple 120mm radiators.
I've had a look at Overclockers for the Swiftech Radbox but can only see it supplied with kits.
Do Overclockers sell it as an individual item ?
Thx.
