Swiftech H20-120 Premium Watercooling Kit??????
12 May 2005
Ripon, North Yorkshire
am in the final stages of putting a list together for my next build and am now looking at cooling options and the main one been the swiftech water kit i have never done a water rig before so am looking for something that is simple to set up safe to use and is a great cooler am going to be using the asus a8n board with a amd64 4000+sd cpu, at the moment am using vapochill micro which is a great cooler for my oced sd chip but will i be better of on water with my new board or sticking with air and if i go for water what can i expect with it, if any1 has one of these swiftech rigs your imput is most welcome :D
take a breath sometimes!
Swiftech make great stuff with everything you need. Top of the line air cooling will get close to the cooling potential of water-cooling but it will likely be louder for the same temperatures. Temperatures only matter though if you are overclocking; if not, air-cooling can cool stock systems well and reasonably quietly. if you are over-clocking, water will usually enable a slightly higher overclock and will be much quieter.
I believe he took 2, but im still imagining his face turning purple
