- 20 Sep 2014
Hi all,
I'm in the process of researching a X99 build which will likely include a 5960X and 2 GTX 980s. I know that to overclock, the i7 needs some sort of water cooling, and I am considering adding the video cards to the loop later on.
I have been trying to find the Swiftech H220x somewhere in the UK, but to no avail. I do like the idea that it comes as a closed loop, but can then be repurposed for a larger loop. However I'm not sure how strong the pump would be for the intended loop, and I am impatient to want it shipped from the USA.
So, I'm wondering, do you think it would be a better idea to just go and get a H100i or similar and then get a completely custom loop if I decide to go that way?
Thanks.
Thanks.
