- 22 Aug 2011
- Ireland
Originally I'd been planning on getting an EK or XSPC 360 kit but, given the time needed to properly install one of these kits I put it off for ages. I also looked at 240mm AIO kit's like the H100i but, I really like the prospect of expansion offered by the custom loops so put that purchase off too. Also, I feel my Monolithic Lian-Li deserves a 360....
Anyway, found a random review of the Swiftech H320 AIO (Full 360mm rad with options to expand) which really grabbed my attention. So, I bought one
arrived yesterday & installed it last night. Took about 2 hours to do as I had to re-orientate the fans to pull as I didn't have the correct screws to mount the rad directly to my top panel & had a bit of a tidy up in there too
Currently run a [email protected] which idled at 46C under a Zalman 9700 & peaked in the 80's under load. With the H320 installed it's idling between 26C & 31C across the cores and under load running Prime95 it's peaking at 49C
Not bad at all, although probably too expensive at £167 delivered
Looking forward to finally upgrading to Haswell or an FX in the next few months.
Unfortunately, I only took a single pic of the box...
.Currently run a [email protected] which idled at 46C under a Zalman 9700 & peaked in the 80's under load. With the H320 installed it's idling between 26C & 31C across the cores and under load running Prime95 it's peaking at 49C
