swiftech mcw60 .ram sinks included ??
yokomo said:
any comments on the block as ive not seen any setups with one or real reviews ?
thanks
Fairly pleased, running on ATI 1900XT with the original HSF idle was around
50c +, with my watercooled setup max I`ve seen 40c mostly idle around 36c.
Installing the block was fairly easy plenty fixings in the box for the different GPU`S, only annoying problem was amount of paste I had to remove from the old cooler.
One thing I would have done is install the ram sinks after the pipe is connected, I kept knocking mine off and they lost their stickyness, long nose pliers come in handy fitting them.
Hope the above helps :)
Rob
cool. my x1900 is HIS turbo (although the clock doesnt seem to want stay at the settings after reboot) idles at48 whil im typing now. ram sink is seperate from the main cooler so il just leave her there.
