Switch binding?
Caporegime
24 Dec 2005
Autonomy
I have my server in the garage...from the garage I have run 3 x cat 6 cable to the switch in the study in the house....currently I have just one live cat 6 connected to the server feeding movies around the house connected to the switch.
Anyway I ran into some buffering issues when I tried streaming 3x 1080p videos to 3 TVs in the house at the same time.
I was chatting to a mate and he said I could bind all three cables in the garage to the switch in the study to make a 3 gig connection from garage to the study improving bandwidth...
Is this possible?
Cheers
streaming 3 blurays you should see no more than 300Mbps (about 37-38MB/sec) absolute worst case. That's well below saturating a 1gb network so something is up there. is there some transcoding going on?
to give you an idea, im streaming 7 copies of a 36gb bluray (1080p) and a 5gb mkv at the same time and according to my microserver, it's upstream peaked at about 50MB/sec which is 400Mbps or something around there. theoretically i could just about do the same again and stream 14 copies without saturating a 1Gbps link but i suspect i would run in to mechanical hard drive limitations (seek times) trying to steam 12 movies at once. If i had SSDs in there it'd be fine im sure.
Does the HP Microserver 54L support it?
N54l has a single NIC, so no, not out of the box. You'd need a dual NIC card in the server but network bandwidth from the server shouldnt be an issue anyway (unless there is a network fault) so it wont help.
Yeah, my money is on a storage IOPS issue, rather than network bandwidth. Transcoding is another good bet on a low-power cpu such as a Microserver uses.
How is your storage configured? If it's just a bunch of mechanical drives in RAID5 it'll struggle. You might be able to do something with increased caching and the use of SSD tiering, but your best bet is probably to set up a second server so you can balance the load.
