I have been asked to find some hardware options for sharing a 1GB connection with up to 70 tenants in a building. Unfortunately I do not have a lot of details at this point, and have only been asked for ideas - rather than concrete specifications.
The requirements we have are to be able to separate each tenant's traffic from each other, rate limit their bandwidth up and down and monitor each tenant's usage.
From that I have figured we need a switch or switches that provides VLAN support and rate limiting on a per-VLAN basis. I am under the impression most modern switches has provision to allow monitoring of bandwidth. The only limitation I have been given is a desire for HP products over Cisco - though as said nothing is set in stone.
Unfortunately, and as you may be able to tell, this is not in my current skill set so hence this thread. Any advice on hardware or what I should be looking for would be a great help. Corrections to my assumptions would be nice too!
No real budget at the moment, but I think a ballpark figure of 2-3K was suggested [so 1-1.5K per switch if more than one is required].
Thanks all!
Thanks all!
