Switch light wiring?
18 Oct 2002
Wellington, NZ
Hi, how would I go about getting the light to come on on this type of switch when the circuit is completed? I'd have thought the light would have come on when the it was a complete circuit, obviously I'm wrong and theres 3 pins.
thanks,
The middle pole is common, so depending on how the rocker is laying, will decide which outer pole is connected to the middle one.
Something like this...
Hope that helps.
Using Mikeyboy's diagram, I would say the middle pin is the positive, and connect the negative to either remaining pins.
AmDaMan said:
so it doesn't need another wire connecting to it?
Cheers.
Nope.
The type of switch will allow you to switch two lamps on and off. ie; Whilst one is off, the other is on.
I'd say neither are Negative, you only switch the Positive.
connect pin 1 to +ve pin 2 to whatever is controlled by the switch and pin 3 to -ve (neutral).
Basmic was the closest ;)
If you look at the side of the switch you can see the load is connected across pins 1 and 2 and the neon/bulb is connected across pin 2 and 3
Fog
Pin 1 is earth I'm sure. As there was a black wire coming from that pin before. The other 2 pins had white wires on.
It's a fan switch for my car, so 12v but I stole the switch from a 240v appliance (would that matter?)
The light will not work for two reasons
1. It requires 240v across it not 12v
2. A 240v appliance is using AC (alternating current) your car is DC (direct current).
It doesnt matter what you do it will never work. (it will work as a switch but the illumination will never work, just to clear that up ;) )
Fog
Fog
It's okay when someone asks the right questions, eh? :p
Pin 1 = item to be turned on and off.
Pin 2 = 12V+ to ignition or battery.
Pin 3 = earth
Before doing this, see if you can get inside the switch to change out the bulb with a 12V one. If not, leave pin 3 unconnected and you have a normal on/off switch with no light.
