Does anyone know if theres any way you can try a Mac before you buy? I am interested in getting hold of one to replace my PC (which is basically an overspec'd CD burner/email grabber/downloader/webbrowser as I have all but given up on mainstream PC gaming) which I will sell in order to finance the purchase of either a mini or an imac with the possibility of a G4 cube if it will do the jobs. Basically I am settling into the computer should do what you need it to do without the fuss mentality, after years of updating/fixing/patching I am finding the whole process a little tiresome as well as expensive (or you can call it the Ipod Halo Effect if you prefer
However I am a little concerned if I can find apps on the Mac to do everything I want/need to do.
Some examples:
Office stuff (Word/Excel compatible as the missus needs them for work docs)
Newsgroup software
DVD/Xvid etc conversion
Sony Ericsson phone syncing (W550i if important)
VNC or equivalent
Decent MP3 tagging (not really a big fan of Itunes tag management - I use Tag and Rename on PC)
SMB Network access (all our backup and media is stored on an NSLU2)
Also from a hardware standpoint do the Macs:
Support Dolby 5.1 via co-ax/optical?
Dual monitors? (I have 1x DVI/VGA and 1x VGA LCD)
I will still have a PC at home in the shape of my Mame cabinet I am building so it doesnt have to do all the above really, just like a close match if poss as that machine is going to be pretty much dedicated to the task in hand.
Final question (honestly
) what sort of CPU/RAM would I be looking at to give smooth performance across the board in Mac terms? My current PC is a 146 Opteron with 2GB RAM and a 6800 Ultra which is well over the top for its current tasks.
A big thanks in advance to any answers.
EDIT:
Should point out to the dons that this kinda crosses both Hardware and Software so would it be possible to keep it here?
Some examples:
Newsgroup software
VNC or equivalent
EDIT:
