Switch to block websites?
6 Jan 2006
Newcastle upon Tyne
I am expanding my business and will be taking on 2 members of staff both at a junior level and I want to block their access to the usual social media sites etc. Is there any switches out there that will allow me to do this? I currently have one internet line coming into the shared office so dont have access to the main router.
Thanks, Mark
Edit - or is there something else I could look at for a solution if a switch doesn't have the functionality?
My only concern with openDNS is that they could easily change the DNS settings to auto configure and bypass the openDNS ones couldnt they?
You could set their host file to auto forward to another site or to a dead address.
Then make the permissions to the file so they can't change it.
That's an easy and free method. Would only work if they always use the same machine every day though.
Otherwise you might be able to block them through your router via MAC address filtering or maybe get a proxy server setup.
if its two people maybe just tell them if they use them during work hours there sacked. But may use it for personal use for x amount at lunchtime?
Untangle might be worth a look for you. We have it running on a N40L microserver and it has proved very reliable (and combined with active directory allows a lot of user control).
You could get a cheap zyxel firewall from ebay, they do some pretty basic web blocking, it would also give you the ability to not block yourself from anything!
They will just use their mobiles :p
Blocking is always a silly idea in my mind. Have some faith, pre-warn them about acceptable internet usage, ensure it is in the Working Policies and if they abuse it, do something.
This sounds good, I will have a look on ebay but I can see what my next thread is - How to set up Zyxel firewall :D
I agree its poor practice but Ive seen it before where staff just sit on the internet all day long and given the nature of the job - admin, they arent hugely accountable so their time is difficult to record.
They are welcome to use their phones, at least I will see from across the office that they arent using their computer whereas their screens will face the opposite direction to me.
