Switch to Micro ATX
13 Nov 2012
Welling
Hi guys, a couple of years ago I built my first pc with an Air 540 case and I now dont have much space in my room so Im thinking to change my setup to a micro atx. What mobo and case would you guys suggest? and is there any other parts I would need to change? I want to make it as small as possible and my total budget is around £200. Thanks :)
Components -
Case - Corsair Air 540
CPU - Intel 4670k
Mobo - Gigabyte Z87X-UD3H
GPU - EVGA GTX 780
RAM - 8GB Corsair Vengeance Pro 1866mhz
PSU - Antec High Current Gamer 750W
SSD - Samsung 840 EVO 250GB
HDD - Western Digital Green 1TB
Watercooling -
Alphacool Nexxxus XT45 240mm
EK Supremacy Clean CSQ
EK DCP 4.0 Pump Res Combo
Bitspower Matt Black Fittings
Hi there are a couple of options with that socket I use a gigabyte G1 sniper which is a fantastic board you also have the ASUS gryphon too. In terms of case keeping the cube shape you have the Corsair 240, fractal design node 804 or what I use is a parvum, or you can grab a small tower
I really like the matx parvum cases, I dont know if i should just keep my components and get the smallest atx case as I dont want to spend too much money. Also would it be possible to fit my watercooling in a ITX parvum case if i was to go ITX
