24 Dec 2012 at 11:59 #1 TBirdUK TBirdUK Soldato Joined 9 Jul 2005 Posts 2,678 Location High Wycombe Is there anything like a sata adapter that is switched so I can have 2 drives into one sata port with a physical switch to decide which one it uses?
24 Dec 2012 at 14:18 #2 bremen1874 bremen1874 Soldato Joined 20 Oct 2008 Posts 12,083 Yes, but they aren't particularly cheap. The forum rules make any direct linking difficult, but just Googling 'sata switch' turns up a few options. What are you trying to achieve? There may be simpler/cheaper ways to do the same thing.
24 Dec 2012 at 14:22 #3 TBirdUK TBirdUK Soldato OP Joined 9 Jul 2005 Posts 2,678 Location High Wycombe I am trying to do a dual boot system that doesn't rely on the bios - so essentially I flick a switch, turn it on, then have the OS that I want
