Not that i've know of, you are better buying a router/modem all in one, or a new modem that is wireless or better still just your average ethernet. I've never been fussed on this USB network lark.
No, these plug into the USB port on a PC to be used as a NIC, it's not literally a converter that you can just plug onto any usb device to make it networkable.
The only one I've ever come across is the Draytek Vigor 2200 USB Router - it was designed to use the provided usb modem with BT OpenWorld back in the day before 'wires only' ADSL was provided & using anything other than the provided modem violated the T's and C's
Only problem is it has been discontinued for quite a while now - you may be able to pick one up second hand via a well known auction website but to be honest you'd be better ditching the modem & getting an all-in-one ADSL (wireless) modem router.
