Switching BB providers, advice needed.
26 Dec 2005
Liverpool
Hi guys.
I am switching from Tesco BB to 02 BB. I called Tesco this evening and requested the MAC code which will be emailed to me within 5 days of request.
Q - Will Tesco BB remain active until 02 have activated their BB or could I potentially lose BB connection for a while?
Currently I use a Netgear DG834g Router for connection to BB. 02 will send their own wireless router in the post once i've ordered. I will use the 02 router as it comes pre-figured for use with 02.
Q - Now obviously i'll disconnect the Netgear from the PC but what do I do about the connection settings currently used for Tesco BB. Do I delete the settings from within the Router login or just delete the Router Login icon from the PC?
Cheers for the advice, never switched BB providers before so just thinking ahead really.
Thanks.
You could use the "Revert to Factory Default Settings" option within the Netgear UI under the Maintenance > Backup Settings menu once you're sure Tesco service has finished.
