Morning all,
I'm currently on the Stronglifts 5x5 program and have been since October. Have made really good progress, lost some belly fat, gained a decent amount of muscle and really improved core strength. But progres is slowing down so I'm now at that time when I'm considering switch to a different program that adds weight more slowly, namely Madcow.
My lifts are currently (all for 5x5)
Squat - 100Kg = 1.3 x body weight
Bench = 62.5kg = 0.8 x body weight
Deadlift = 110kg = 1.4 x body weight
OHP = 42.5kg = 0.55 x body weight
Row = 70kg = 0.9 x body weight
I'm finding that now adding 2.5kg each time seems to much and I need more volume at the current level. I know the advice is to stay on the beginner program as long as possible as you'll gain more in shorter time, but in light of the above what do you think?
Cheers
Cheers
