Right, I'm running a 6870 with 2 x 22" monitors on DVI and the TV on HDMI.
The only trouble being I can only run 2 at a time, which is fine because I'm either watching the telly or looking at the monitors.
Only thing is it's very cumbersome to switch between, I have to disable a monitor then enable the tv, then change it all back at the end.
Is there any way I could automate this, either by having it automatically change when I open/ close xbmc or maybe some kind of batch file, or program I can use to quickly switch between the two?
