The RAID drivers normally wouldn't install before the BIOS has been set accordingly but if the BIOS is set to RAID then the PC most likely won't boot.
If you have another SATA controller then you could do what I did. Move the OS boot drive over to this controller and make sure it's running in IDE mode. Boot the system up to make sure it boots, change the BIOS settings for the other SATA controller to RAID and boot, install the drivers and reboot to make sure the system comes up. Then shut down and move the OS disk back onto the main controller and hopefully the system should boot up.
