Switching to Talktalk fibre from BT
4 Nov 2003
I am switching over from the BT fibre to Talktalk fibre. I currently have the openreach modem connected to my Asus router.
As Talktalk uses the BT network, can I just keep my setup as it is without having to install new equipment that Talktalk give me as it appears that there is no need for any log in credentials.
Also does anyone know if the openreach modem is good for 150mbs speeds or will I need to be looking at a draytek?
Thanks in advance
What service are you moving from and to? It sounds like currently you're on FTTC but to get to 150Mbps means you're either moving to G.fast or FTTP - which one is it?
I believe it's G Fast. I am moving from BT 75mbps fibre service to 150mbps fibre on talktalk. No need for any new installation of cables etc
I am having the switch over on Wednesday. Does anyone have a Nest WiFi running on talktalk? Just wondering if I would need to change any settings to get it to work.
