Is it true that a thicker oil may prevent loss in an older, more worn engine? My 1999 Focus 1.6 has been faultless since I owned it, but I have noticed that it tends to use oil. Ive scratched my head trying to figure out how and why; it doesn't leak anywhere that I can see. There's no mayo in the filler cap or loss of power. Exhaust fumes are clean, it never visibly burns oil. The engine has never failed to start after just one or two cranks and sounds/runs smoothly for a relatively old engine. The only explaination I can come up with is that as it's now jsut voer 10 years old and on about 97K miles, it must simply be using slightly more oil.
Recommended grade is 5W-30 for Zetec engine, but the manual says that 5W-40 and 10W-40 are also acceptable if 5W-30 is unavailable, but at the risk of lower efficiency. Would it be worth switching to one of these thicker oils to slow the oil loss?
The engine is absolutely sound apart from this, lives a sedate life with me and gets serviced annually at home. It's been about 6000 miles since the last service, and I was considering giving the oil a change anyway, but I'd like to now more about oil thickness and if it would help at all before i changed it.
