Hi all, I have a samsung syncmaster 2032mw monitor.
When you turn it on it comes on for 1-2 seconds then switches off again. I took it apart, presuming capacitors would be to blame but they all seem fine.
The connections on an inductor coil however look a bit iffy. Wondered what the symptoms would be for this, or where else to look on the board for a fault.
I'm still a bit of a novice with circuit boards so may not understand anything too technical. There is a resistor/ transistor next to the inductor coil (can't remember which now as I'm not looking at the board) It has orange enamel coating on top that has a slight crack in it. This is the only other thing I'v noticed on the board.
Hope this all makes sense and thanks
