- 1 May 2006
- Bristol, UK
As the title. I need to sync my laptop and PC user profiles just to keep everything tidy.
Basically it will be syncing the C:\Documents and Settings\[username] folder in its entirity.
Anyone had any experience with this? I imagine that there will be a lot of files that I wont be able to sync because they are in use by the system. Is this correct?
Cheers
Cheers
